SailNet Community - View Single Post - pics of sail covers made for lazy jack systems?
post #10 of Old 05-03-2014
TQA
Bombay Explorer 44
TQA's Avatar
Re: pics of sail covers made for lazy jack systems?
This is mine. It is based on a Mack stack pack. As you can see the lazy jacks run through grommets near the top of the side pieces. This helps stop things flapping even when the lazy jacks are slackened off and led forward. The zip on the top has a continuous line which means it can be undone standing at the mast and helps when it needs to be zipped up. The sides are attached to the mast with two turnbuckles and a hook per side.
I am happy with it and if it wears out will get it copied without change. I have thought about battens but see no real advantage.
TQA is online now
