SailNet Community - View Single Post - Proper winch technique?
post #12 of Old 05-04-2014
bristol299bob
bristol299bob's Avatar
Re: Proper winch technique?
Originally Posted by jackdale View Post
1) Too many wraps on the winch to start. You really only need two (maybe three to start. This one will have 5 when finished. That is a clear invitation to an override.
2) The line should be held with the thumbs away from the winch, it is easier to pull on the line that way. And easier to let go if needed.
3) The other hand should never be used loop lines onto the winch. Having your hand inside the bight could result in that hand being jammed into the winch if the line starts to run.
This is a good video.
I teach three the standards for 4 different organizations. They all agree on this approach to winch safety.
How do you avoid, or cope with, twists in the sheet that form when you unwrap? These twists tend to jam in the jib car as the jib moves across.
You can see the twists I mean in the video at about 2:20. I single hand so rather than "let it fly" and pull in on the new leeward side I let it fly ... Then pull in, then back to the windward side and un-jam ... Then haul in on the leeward ... Then back to windward to un-jam, then back to leeward for the final adjustment. Very inelegant, maddening at times.
Is it technique, or perhaps I need a more slippery jib sheet?
1977 Bristol 29.9
Surprise
Hull #5
Oriental NC
bristol299bob is offline
