SailNet Community - View Single Post - Proper winch technique?
post #13 of Old 05-04-2014 Thread Starter
jackdale
jackdale's Avatar
Re: Proper winch technique?
Originally Posted by bristol299bob View Post
How do you avoid, or cope with, twists in the sheet that form when you unwrap? These twists tend to jam in the jib car as the jib moves across.
You can see the twists I mean in the video at about 2:20. I single hand so rather than "let it fly" and pull in on the new leeward side I let it fly ... Then pull in, then back to the windward side and un-jam ... Then haul in on the leeward ... Then back to windward to un-jam, then back to leeward for the final adjustment. Very inelegant, maddening at times.
Is it technique, or perhaps I need a more slippery jib sheet?
I flake the sheets rather than coil. (Actually I flake rather than coil in almost all instances.) That seems to help avoiding jams.
As well single-handing - you can take the lazy sheet across the cockpit with you. A quick tug should release the jam.
jackdale is offline
The Following User Says Thank You to jackdale For This Useful Post:
bristol299bob (05-04-2014)
