SailNet Community - View Single Post - stoves: propane vs alcohol
post #8 of Old 08-16-2007
DrB
Originally Posted by camaraderie View Post
Certainly propane is less safe than alchohol and makes a big bang when safety and maintenance is not attended to properly. Still...most of the rare explosions one hears about are the result of carelessness or neglect rather than "accidents". So...I am comfortable using propane as a fuel and vastly prefer it to alcohol as a convenient and effective cooking fuel. I have owned alchohol stoves before and remember waiting forever to try to get a large pot of water to boil. While there may be improvements in more modern alcohol stoves...the heat of the burners can't be that close to my LPG stove. I have never seen any tests of this and would be happy for a reference...but in the meantime will submit a link on camping stoves. One would think these would be designed for maximum efficiency since you have to carry your own fuel. The table shows all of the alchohol burners taking 2-3 times as long as the gas stove to boil 2 cups of water.
http://hikinghq.net/stoves/stove_compare.html
That is similar to my experience on board.
Agree.
I have a lot of experience with camping stoves and almost all campers that I have backpacked with use either White Gas or Propane Canisters. Nobody I know uses Sterno (alcohol) stoves for major cooking. While WG burns a little hotter it is much more hazardous than propane canisters. WG needs to be handled smartly, especially when cooking inside your tent. Yeah, I know that you are not supposed to cook inside your tent, but when it's pouring rain or snowing, cooking in the vestibule is the only way. WG also needs to be primed (pump), whereas Propane doesn't.
Agree with others, if you have the plumbing, and it is in good shape and safe, propane is the way to go. Alcohol is safer, but you won't be able to cook much except boil water.
DrB
PS - White Gas is typically what is used in Coleman Liquid Fuel stoves.
DrB is offline
