SailNet Community - View Single Post - Shoal draft keel versus regular fin keel
post #19 of Old 08-17-2007
Sailormann
Here .. Pull this
Unless you are planning on racing a fair bit, the performance issue is not a big one. The difference between a specific boat with a shoal keel and the same boat with a fin keel is usually measured in the single digits (per mile). You need to be a very good sailor to take advantage of this.
If you like the boat - buy it and don't worry much about the keel. If it was designed to sail with a shoal keel then chances are it will work well. BTW - a properly designed wing keel will provide slightly better off-wind performance than a fin...
Sailormann is offline
