SailNet Community - View Single Post - What life jacket do you recomend...
post #18 of Old 08-17-2007
RealityCheck
RealityCheck's Avatar
I would not get too comfortable thinking about the Auto inflate units assisting you if you are knocked out... They WILL NOT keep you face up... you would probably still drown but your body would be easier to recover. Also you would need the crouch strap to keep the jacket from popping off your limp body. Each person needs to determine which type jacket to use in in specific circumstances.. they will vary depending on what your doing and the conditions. Generally the auto inflates cost more but generally do not provide a significant additional protection... maybe if both arms are broken and you can't pull the manual inflate or reach the mouth inflate tube... but if your knocked out... the auto-inflate will probably not help you survive at all as you face will be in the water.
RealityCheck is offline
