SailNet Community - View Single Post - The bottom line on Ham radio
post #5 of Old 05-07-2014 Thread Starter
davidpm
davidpm's Avatar
Re: The bottom line on Ham radio
Originally Posted by SVAuspicious View Post
All correct with one caveat. Unlocking a marine radio that does not result in any change to the type-accepted radio (like the front panel unlock code for an Icom M802) is not, to my knowledge, even technically against the rules.
That makes sense but I can't find anything definitive about that.
Apparently their is still the issue that the marine radio is dummed down enough that as a ham you may not be able to do what you want.
davidpm is offline
