SailNet Community - View Single Post - Proper winch technique?
post #16 of Old 05-07-2014
Uricanejack
Re: Proper winch technique?
I tend to agree with Jackdale about winch technique. Though I add in lean over the winch as you put the wrap on and keep your hand about a foot away from the drum.
Stand above and pull straight up. as said by med sailor.
Never found a coiled sheet to be a problem.
Lines wet which have dried can be stiff. if they are a bit kinked chuck the tail over and two for a while it will remove any kinks
Uricanejack is offline
