SailNet Community - View Single Post - Sailboat advise please...?
post #3 of Old 08-21-2007
sailingdog
How many people are going on this extended trip? The best advice I've heard on buying a sailboat is that "the Primary use is primary." That means, if you're sailing singlehanded or as a couple, then you don't really need a boat with three cabins and two heads. Almost any boat larger than 20' is going to have two berths... A berth is where you can put a sleeping body... a CABIN is where you usually have a double berth and some additional privacy... Berths ≠ Cabins...
I, too would like to know what sailing experience you've got... given that you're looking for a boat that can do bluewater passages. What have you looked at, and why did you not like them? Saying what you don't like would help eliminate a lot of good suggestion that you will reject out of hand and save us from wasting our time.
Also, fast and comfortable generally don't go hand in hand on a sailboat. The faster the boat, generally the less comfortable it will be, unless you have a lot of money.
You could also do a search on the boat buying forum, since you've indicated that you like center cockpit boats, since there have been several threads on center cockpit boats.
sailingdog is offline
