SailNet Community - View Single Post - 1st big project, bronze thru-hull
post #5 of Old 05-09-2014
Rhapsody-NS27
Daniel - Norsea 27
Rhapsody-NS27's Avatar
Re: 1st big project, bronze thru-hull
I used G10 for the base too. I didn't use studs, nor did I use bolts through the hull.
I drilled through the bolt holes, then drilled a little larger area for the bolt heads so they would be recessed into the G10 plate.
Next time I haul out, I will have 6 or 7 more to replace and plan to install the same way. MaineSail's instructions were great help.
Daniel
1981 Nor'sea 27,
“Who is staring at the sea is already sailing a little.”
-Paul Carvel
Rhapsody-NS27 is offline
