SailNet Community - View Single Post - Air Conditioner Issue
post #13 of Old 05-09-2014 Thread Starter
UnionPacific
Schooner Captain
UnionPacific's Avatar
Re: Air Conditioner Issue
Originally Posted by Brewgyver View Post
The cap is almost certainly dead, and caps are cheap. Test the compressor windings. With all leads disco'ed, use ohmmeter to check from C to S, and then from C to R. If you have continuity (it will basically be sero ohms), then check from C to the shell of the compressor. That should be open (infinite resistance). If both these are true, your compressor is probably OK. Could be bad mechanically, but that's less common than a burnout. Hope that's the case!
ok, C to S, C to R both 0
C to shell, 1 so no connection from case to C.
I made sure by touching both to case and getting 0 then moving one to C and still nothing. So bad cap, right?
UnionPacific is offline
