Originally Posted by labatt
SD - I won't go so far as to ask if it uses CTS/RTS for flow control.. I assume it's a bit more modern than XON/XOFF  I can geek too...
Damn... Brak beat me too it... CTS and RTS each require signal lines... which NMEA doesn't require. The three wires in the NMEA are a data-in, data-out and ground... and if you are connecting a listen-only device, like a DSC-capable VHF, you only need two wires. The Standard Horizon 471 handheld has two wires for the NMEA GPS data in connection.
My guess is that Brak is right... that NMEA 0183 doesn't support any flow control whatsoever. That may be one reason the standard is limited to two talker devices per connection.
To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts..
