SailNet Community - View Single Post - How Low Can We Go? (hp)
post #9 of Old 05-11-2014
dabnis
Re: How Low Can We Go? (hp)
[QUOTE=juggleandhope;1828650]Thanks for the replies.
Right now I'm thinking that for this season I'll just keep the one I've got and pull it out of the well when it will be several days before I use it again, just lay it on its side (2 strokes don't mind that, right?).
Probably before that I'll try out some smaller hp engines just to see it, from someone in the club.
If I do decide to do the surgery it won't be as simple as Baldwin's - I'd be cutting into the area between the transom and the existing well. So I'd have to put up small bulkheads to keep a following sea from flooding into the actual boat, under the cockpit. Probably would have to cut off the back wall of the well and then extend the existing 3 sides back to the transom. A lot of scary work, there.
From the pictures I think cutting a hole in the transom would be risky business. The whole structure seems to be all tied in together. Might not be good strength & re-sale wise? If you get a chance take a look at the well arrangement on a Coronado 25. Pretty good design & done by the factory. Yours looks a whole lot different.
Paul T
dabnis is offline
