SailNet Community - View Single Post - First haul-out
Thread: First haul-out
post #2 of Old 08-26-2007
NOLAsailing
NOLAsailing's Avatar
1. Check your zinc(s). If they are at all deteriorated, replace them while the boat is out of the water.
2. Check your cutless bearing. If there is significant side-to-side movement, it may need to be replaced.
3. Check your prop. If it is at all pink or doesn't resonate, it may have had the zinc leached out. If it is dezincified, it will be brittle.
4. Check the keel/hull joint, though if there is a problem there, I'm sure you would have noticed it by now. Likewise with the bottom paint.
5. Check the strut.
6. Check the rudder, gugdeons, pintles, etc.
-Jason
NOLAsailing is offline
