Joe...If you already have significant scaling in your hoses and valves, you may need to be more aggressive than vinegar. Muriatic acid pumped into the lines is the way to go. Then...once you are clear...you can use vinegar for maintenance.
Full procedure here:
http://www.boatus.com/boattech/casey/04.htm
