SailNet Community - View Single Post - Outboard motor charging upgrade
post #1 of Old 05-17-2014 Thread Starter
This Old Sailboat
aka $tingy Sailor
This Old Sailboat's Avatar
If you don't already have a charging circuit on your outboard, but you're lucky enough that it already has generator coils installed, you might consider adding the missing rectifier/regulator to charge your battery bank.
That was the case recently with my 2004 8HP Yamaha 4-cycle. It wasn't hard to find the part (used, even) and install. Now my battery can recharge with 2-5amps whenever we're motoring. It might not meet all of our future on-water charging needs but for only $71, it's worth a try. Time will tell.
I published the full story today in Outboard motor charging solution on my blog.
Explore over 100 DIY sailboat restoration and improvement projects at
This Old Sailboat is offline
