SailNet Community - View Single Post - My engine is getting too hot..
post #9 of Old 08-27-2007
k1vsk
If you had the heat exchanger manifold off last year for cleaning, I would suspect something else. Regardless, if you want to use muriatic acid, run it through a warm or hot engine and let it sit for 15 min or less (no absolute max) and run to flush. If you're worried about gaskets and impellers being effected, just dilute the acid with some vinegar.
k1vsk is offline
