While you can often replace wire-to-rope halyards with all rope halyards, you need to check the masthead sheaves to see if they are large enough to accept the rope and of the right profile to not damage the rope.
Sheaves used for rope generally have a u-shaped profile to the groove, while sheaves for wire generally have a v-shaped profile to the groove. While you can sometimes use v-shaped wire sheaves on rope, it will tend to cause the rope to wear through faster than if you had the proper sheaves.
