StaSetX is a good choice for reduced stretch, since it has a parallel core, instead of a braided core. However, it is a bit stiffer than regular Sta-Set lines. If you want minimal stretch and less weight aloft...go with NERopes T900, which has about the same stretch as the wire you're replacing—1-1.5%. The core on this rope is made of Spectra. However, be aware that the high-tech core lines are a bit more difficult to tie knots in, so you'll need to have the rigging shop put a shackle on the sail end for you. I prefer the captive screw pin shackles by Wichard, that have the blue plastic line thimble built in.
