Old 08-27-2007
sanctuarysam's Avatar
sanctuarysam sanctuarysam is offline
purveyor of mischief
sanctuarysam will become famous soon enough
thanks Cam & Quick...
how do/did you deal w/ the prop and shaft using an ablative... a friend recommended using interlux primer. the reason i ask, during my last outing i found significant "crusties" on my prop and shaft causing enough resistance to cause soot in my exhaust and significantly reduced RPMs, after braving the stinging nettles i scraped enough off to correct the problem.
any thoughts?
