Old 08-27-2007
NOLAsailing's Avatar
NOLAsailing NOLAsailing is offline
NOLAsailing is on a distinguished road
I'll second the Windex recommendation, though it won't tell you wind speed. For that you'll need a wind instrument, of which there are many choices. I like the TackTicks, personally.
If at all possible, put the Windex (if that's what you go with) on after the mast is re-stepped. The mounting bolt can be installed with the mast on the ground. Then put the rest of the Windex together before you go up the restepped mast and you can just screw it onto the previously installed mount.
- Jason
Rambunctious, J/30
www.rambunctiousracing.com
Sponsored Ad
