SailNet Community - View Single Post - Transducers
Thread: Transducers
post #6 of Old 08-27-2007
sailingdog
Yes, I would install the transducer specific to the GPS/Chartplotter/Sounder. The reason you don't want to try and use a transducer with an unknown heritage is that you can't be sure what the signal out format is. Airmar sells much the same transducer with several different electronic configuration, even though the physical configuration is almost identical.
For instance, the DST800 Triducer (speed, depth, temp) is made in four different configurations for Furuno, Raymarine, and TackTick. If you had the TackTick one, and bought a Furuno display head, chances are pretty good that it would fail to work.
Originally Posted by alecs123 View Post
SD, I'm thinking of getting a GPS-Sounder combo, would you say it's better to install a new transducer specific for the GPS? and get rid of the old one?
Since I'm not sure I will go with the GPS, just a stand alone depth sounder made sense to me initially, but by what you said I think it's better to use transducers specific to system/brand.
Thanks
sailingdog is offline
