Old 08-29-2007
sailingdog sailingdog is offline
sailingdog is a jewel in the roughsailingdog is a jewel in the roughsailingdog is a jewel in the roughsailingdog is a jewel in the rough
If you have one of these:
and it is adjusted to read true north, he must have used the compensators to do this. However, I'm not sure if the compensators could alter the compass readings 15˚ accurately over the entire 360˚ range of readings. I would bet that the compass isn't accurate for true bearings all the way around. What you need to do is swing the compass and have it re-adjusted to read properly.
The reason I think it is very important that you do this, is that if you get used to this compass the way it is, and get on another boat... the chance of you making a huge navigation error is rather high... Likewise, if you have someone else at the helm of your boat, and they're not used to a magnetic compass reading true... you're much more likely to have a problem. Navigation errors can result in very, very, expensive repairs.
If you're new to the Sailnet Forums... please read this POST.
