Thread: Through-Hulls
Old 08-29-2007
kwaltersmi's Avatar
kwaltersmi kwaltersmi is offline
Broad Reachin'
kwaltersmi is on a distinguished road
Through-Hulls
My current project boat (Helms 25) only has one through-hull. The through-hull is plumbed to two separate drains in the cockpit. My plan is to add a through-hull or two for a couple of bilge pumps I plan to install. Frankly, I'm surprised that the boat didn't come from the factory with a through-hull for a bilge pump.
My question is: How do I determine the proper location in the bilge to mount the pumps? I would assume that at least one should be in or very near the lowest part of the bilge. My initial thought is that the back-up bilge pump should be mount a bit higher in the bilge.
S/V Hannabel - Helms 25, Hull #44
Home Port: Grand Haven, Michigan
Sailing Blog: http://www.sailblogs.com/member/dreambegins/
