I wouldn't put the through-hull for the bilge
pumps below the water
line. That makes it very difficult for the
pump to evacuate the water... since it has to fight the pressure of the water on the output
lines... Generally, the output for the bilge
pumps is above the waterline.
I would mount a small "maintenance" bilge
pump down in the bilge as low as possible, with a relatively small capacity and a relatively small diameter hose. This minimizes the return water that comes down the hose when the
pump shuts off. Then mount a larger, high-capacity
pump about the same level, but with its switch a bit higher than the one for the small maintenance
pump. That way, this larger
pump will empty the bilge if the small
pump gets overwhelmed, but will stay off otherwise.
POST.
