Old 08-30-2007
sailingdog sailingdog is offline
sailingdog is a jewel in the roughsailingdog is a jewel in the roughsailingdog is a jewel in the roughsailingdog is a jewel in the rough
If you have a swing keel—which is just a weighted centerboard in reality—then you will blow about a bit, but depending on the draft of your boat and the hull design, it may or may not be a big problem.
I find on my boat, which is a centerboard design, that if I don't have the board at least a third of the way down, the bow tends to blow off pretty easily. This is probably due to the fact that the boat's hulls have a very shallow draft—only 14" or so, and that the boat is rather light for its size—3800 lbs and 28'... and that it has a bit more windage than some boats its size, since it is a trimaran.
If you're new to the Sailnet Forums... please read this POST.
