SailNet Community - View Single Post - How much of a propane smell?
post #2 of Old 08-30-2007
sailingdog
Labatt-
I don't think you should be getting the propane odor if the burner is working properly. Mercaptan, the odorant used in the propane, should burn off in the combustion of the propane. Smelling it at the initial start is normal, since some propane is probably escaping when you go to light the stove. I would check the connections in the stove and gas lines for a possible leak.
sailingdog is offline
