Old 08-31-2007
sailingdog sailingdog is offline
sailingdog is a jewel in the roughsailingdog is a jewel in the roughsailingdog is a jewel in the roughsailingdog is a jewel in the rough
The NMEA 0183 shouldn't be a COAX cable, since NMEA 0183 is a serial connection. Last I checked, you need a GPS unit, or a GPS antenna that has an NMEA0183 output. BTW, a GPS antenna that has an NMEA0183 output is really just a GPS unit with no display or controls—pretty useless IMHO.
I would recommend you get one of the handhelds, that could be used in a life raft in an emergency, like the Garmin GPSMap 76C. This can run on AA batteries, but can also run off a DC power supply, via the NMEA 0183 cable.
As for the headphone jack, have you tried it with a regular set of headphones to see if it is functioning properly??
If you're new to the Sailnet Forums... please read this POST.
