SailNet Community - View Single Post - Smelly water from fresh water tank
post #17 of Old 08-31-2007
k1vsk
Smells are often mis-attributed to the tank(s). If you cleaned it out thoroughly, that would only confirm that. A smell so pervasive is more likely coming from under then tank, particularly as it had leaked in the past, or in hidden spaces such as under a hull liner. Sounds like you need to investigate further.
k1vsk is offline
