Old 08-31-2007
Boasun's Avatar
Boasun Boasun is offline
Boasun will become famous soon enoughBoasun will become famous soon enough
May just need new gaskets, hose clamps, shaft seal and/or other connections.
So take it apart and reassemble with new gaskets, insuring that you use cross tightening on the screws. Also that all of the hoses (hose clamps) are properly fitted to the pump and any other connection is properly tightened.
solved many a leak on an engine by doing the above.
As you work on the pump you can inspect the body of the pump for any cracks and may need to replace the seal also.
There should be an after market rebuild kit for the pump that is easy to acquire to do the job.
Sponsored Ad
