Hi Max -
Well I made an offer and it was accepted.
Now trying to determine what needs done first.
The PO had a transport company move the boat to its present location - when they took the mast down they cut all the wires. He had not bothered to reconnect them as he only uses the boat in an estuary.
Also - the depth transducer is bad according to the PO. Any way to ohm it out (what should the readings be) Do I have to haul the boat to replace it?
The seacocks are some kind of plastic ball valve - grey in color. It has the original glassed in nipples for through hulls.
The boat will be used off the Oregon coast - 5 - 35 knot conditions, so will need a hank on jib for this.....could you make a recommendation?
Thanks for your help
