SailNet Community - View Single Post - Cetol Marine Finish Woes
post #27 of Old 05-25-2014
lennyv
Re: Cetol Marine Finish Woes
Try wiping the wood with acetone before applying the cetol. It will remove moisture from the wood. Also let the cetol breathe a few moments in the shade after stirring. I use cetol with a foam brush and put it on as thin as possible. A few thin coats are better than 1 thick coat. Good luck
lennyv is offline
