Old 09-01-2007
sailingdog sailingdog is offline
sailingdog is a jewel in the roughsailingdog is a jewel in the roughsailingdog is a jewel in the roughsailingdog is a jewel in the rough
I'm not crazy about the idea of moving the tank up into the port locker. That's about 175–200 lbs. of weight that you'll be putting there when the tank is full, and you're removing about 150 lbs. from the bilge. However, if many people have made this modification without problems, it should be okay for you to do it... and then you could convert the space where the existing tank is into additonal space for batteries... and make a larger house battery bank.
If you're new to the Sailnet Forums... please read this POST.
