SailNet Community - View Single Post - Leak in Drive Shaft for Inboard
post #2 of Old 09-02-2007
Tartan34C
Judging by the amount of threads remaining you need to repack the stuffingbox. But more then that you need to disassemble everything and clean it using a mix of white vinegar and salt using a stiff bronze wire brush. The corrosion is caused by the leaking saltwater getting over everything in the area. There is no bearing inside the stuffingbox.
All the best,
Robert Gainer
Tartan34C is offline
