Old 09-04-2007
sailingdog sailingdog is offline
Originally Posted by 6string View Post
Would you be able to use the engine in reverse to slow boat speed before making a maneuver if you were uncomfortable with speed? I doubt the engine in reverse would overcome your forward momentum but it should slow you down and help add some control ? ? ? ?
Most larger sailboats have issues with prop walk, which is exaggerated in reverse and would possibly make the situation worse.
