SailNet Community - View Single Post - Turning Diesel Key Off?
Old 09-05-2007
sailingdog sailingdog is offline
The only way to kill a diesel, since it doesn't depend on electricity—having no spark plugs or ignition coil—is to cut off either the air or the fuel to the engine. On some engines, usually smaller ones, the air is cutoff... on most the fuel is shutoff. The only thing the key is required for on most diesels is to provide a safety mechanism to prevent someone from starting the engine unexpectedly. Hotwiring a diesel is pretty simple, since you only have to hotwire the starter motor for a short period of time...
Turning off the battery switch, unless you have a ZapStop device installed, or disconnecting the batteries will cause the alternator to burn out the diodes that allow it to function. On a diesel engine, this is a problem, but not as serious as it would be on a gasoline engine, which requires electricity to continue to operate...and will drain down the batteries as a result of this.
I don't believe turning the key off had anything to do with the remote monitoring panel, but it really depends on how things are wired. Unless your boat is wired in a seriously strange way, I doubt that you fried the alternator diodes.
