SailNet Community - View Single Post - Yanmar 3GMD transmission oil confusion in manuals
post #16 of Old 05-30-2014
casey1999
casey1999's Avatar
Re: Yanmar 3GMD transmission oil confusion in manuals
Here is a good link that tells what oil for what transmission:
http://www.sailnet.com/forums/diesel...-new-post.html
I see where a KBW10D can be mated to a Yanmar 3GMD and the trans calls for Dexron II/III ATF 24 ounces- so you need to see if you have a KBW 10D transmission.
(Note the # after oil type is volume in ounces)
Page:
Capacity Chart
Model Application(s) Fluid Type/ Ounces/ Rotation
KM2A 1GM/2GM/3GM SAE 30W /10 /Clockwise
KM2C 1GM10/2GM20 SAE 30W 10 Clockwise
KM2P 1GM10/2GM20/3GM30V SAE 30W 10 Clockwise
KM2P-1 2YM15/3YM20/3YM30 SAE 30W 10 Clockwise
KM3A 3GM/3GMF/3JH2 SAE 30W 15 Clockwise
KM3A-1 3JH2E SAE 30W 15 Clockwise
KM3A-2 3JH3E/4JH3E SAE 30W 15 Clockwise
KM3P 3GM30F SAE 30W 12 Clockwise
KM3P-1 3JH2E SAE 30W 12 Clockwise
KM3P-2 4JH2E SAE 30W 12 Clockwise
KM3P-3 3JH3 SAE 30W 12 Clockwise
KM3P-4 3JH3E/4JH3E SAE 30W 12 Clockwise
KM3V 1GM/2GM20/3GM30V SAE 30W 10 Clockwise
KM35A 3JH3/4JH3 SAE 30W 22 Clockwise
KM35A2 4JH4E SAE 30W 22 Clockwise
KM35P 3JH3/4JH3 SAE 30W 17 Clockwise
KM4A 4JH ALL/4JH2 ALL SAE 30W 44 Bi-Rotation
KM4A-1 3JH3E/4JH3E SAE 30W 44 Bi-Rotation
KM5A 4LH-TE/THE/DTE SAE 30W 71 Bi-Rotation
KMH4A 4JH3 TURBO SAE 30W 68 Bi-Rotation
KMH6A 6LY(A)-UTE SAE 30W 135 Bi-Rotation
KMH60A 6LYA/6LY2A-STP SAE 30W 135 Bi-Rotation
KMH61A 6LY3-ETP SAE 30W 135 Bi-Rotation
KBW10 2QM15 Dexron II/III ATF 24 Clockwise
KBW10A 2QM20H Dexron II/III ATF 24 Clockwise
KBW10B 2QM15 Dexron II/III ATF 24 Clockwise
KBW10D 3GMD Dexron II/III ATF 24 Clockwise
KBW10E 3HM/3HM35 Dexron II/III ATF 24 Clockwise
KBW20 4JHE/4JH2E Dexron II/III ATF 40 Clockwise
KBW20-1 4JH3E Dexron II/III ATF 40 Clockwise
KBW21 4JH-TE/4JH2-TE Dexron II/III ATF 40 Clockwise
SD20 GM/YM SAE 80/90 GL4/5 74 Clockwise
SD30/31 JH up to 56hp SAE 80/90 GL4/5 74 Clockwise
SD40 JH3/JH4 non turbo HP Gear Lube 71 Clockwise
SD40-T 4JH3-TE HP Gear Lube 71 Clockwise
SD50 Replaces SD40 HP Gear Lube 74 Clockwise
YX70S-1 6CX-ETE SAE 30W 169 Bi-Rotation
Transmission Specifications Application
Manufacturer Model AKA Ratio(s) Fluid Type Ounces
Velvet Drive 1005 V-Drive 1.2:1 / 2.5:1 DEXRON II/III ATF 28
1017 71 1:01 DEXRON II/III ATF 64
1017 71 1:05 DEXRON II/III ATF 94
1018 72 1:01 DEXRON II/III ATF 64
1018 72 1.52:1 / 2.91:1 DEXRON II/III ATF 94
2001-001 to 006 5000 ALL DEXRON II/III ATF 64
2002-002 to 005 5000 V-Drive ALL DEXRON II/III ATF 94
Walters RV-10 ALL SAE 30W 16
RV-20/26 ALL SAE 30W 33
RV-30/36 ALL SAE 30W 48
RV-40 ALL SAE 30W 64
RV-48 ALL SAE 30W 64
Hurth/ZF HBW40/50 ZF4M/5M ALL DEXRON II/III ATF 10
HBW100 ZF10M ALL DEXRON II/III ATF 12
HBW150A ZF15M-A ALL DEXRON II/III ATF 17
HBW125/150 ZF12M/15M ALL DEXRON II/III ATF 19
HBW150V ZF15M-1V ALL DEXRON II/III ATF 34
HBW250 ZF25M ALL DEXRON II/III ATF 25
HSW250A ZF25A ALL DEXRON II/III ATF 60
HSW250H ZF25A ALL DEXRON II/III ATF 68
HSW450A2 ZF45A ALL DEXRON II/III ATF 68
HSW450H2 ZF45H ALL DEXRON II/III ATF 101
HSW630A ZF63-1A ALL DEXRON II/III ATF 135
HSW630H ZF63-1H ALL DEXRON II/III ATF 128
HSW630V ZF63-1V ALL DEXRON II/III ATF 135
HSW800A2 ZF80-A2 ALL DEXRON II/III ATF 186
HSW800V1/V2 ZF80-1V/2V ALL DEXRON II/III ATF 236
IRM220A ZF220A ALL SAE 30W 135
IRM220PL ZF220 ALL SAE 30W 135
IRM220V-LD ZF220V ALL SAE 30W 169
IRM220V-2 ZF220V ALL SAE 30W 135
IRM280A ZF280A ALL SAE 30W 135
IRM280PL ZF280P ALL SAE 30W 135
IRM280V-DL ZF280IV ALL SAE 30W 202
IRM301A ZF301A ALL SAE 30W 220
IRM301PL ZF301C ALL SAE 30W 220
Engine Oil (Note for older models refer to your manual- manual is correct):
Sailboat Supplies, Engine Parts and Boat Parts
Yanmar Engine Oil and Fuel Capacity Engine Model Quarts of Oil* Oil Type** Quarts of Coolant*
Recommended Coolant
1GM10 1.6 15W40 N/A YG30R or DexCool***
2GM20F 2.1 15W40 0.77 YG30R or DexCool***
3GM30F 2.7 15W40 0.9 YG30R or DexCool***
2YM15 1.9 15W40 3.2 YG30R or DexCool***
3YM20 2.6 15W40 4.3 YG30R or DexCool***
3YM30 2.6 15W40 4.6 YG30R or DexCool***
3JH3E 5.2 15W40 5.6 YG30R or DexCool***
4JH3E 5.6 15W40 7.2 YG30R or DexCool***
4JH3-TURBO 7.4 15W40 7.2 YG30R or DexCool***
3JH4E 5.3 15W40 4.8 YG30R or DexCool***
4JH4E 5.8 15W40 6.4 YG30R or DexCool***
4JH4-TURBO 6 15W40 7.6 YG30R or DexCool***
4LHA-TURBO 13.7 15W40 14.8 YG30R or DexCool***
6LP(A)-TURBO 10.6 15W40 14 YG30R or DexCool***
6LY(2)A-TURBO 21 15W40 21 YG30R or DexCool***
6LY3-TURBO 20 15W40 30 YG30R or DexCool***
4BY 8.5 5W40-SYNTHETIC 10.6 YG30R or DexCool***
6BY 11.5 5W40-SYNTHETIC 14.3 YG30R or DexCool***
6CX-ETE 24 15W40 38 YG30R or DexCool***
6CX-GTE(2) 23 15W40 38 YG30R or DexCool***
6SY-TURBO 29 15W40 42 YG30R or DexCool***
8SY-TURBO 35 15W40 79 YG30R or DexCool***
* Capacity levels should be considered approximate.
** Engine oil specifications will vary by location.
*** All new / replacement installations of Antifreeze in Yanmar engines must include the following specifications:
Silicate - free
Phosphate - free
Organic acid base
Protects all metals including Aluminum
Meets or exceeds ASTM D3306 &D4985
Long Life
Contains no borates, nitrates, amines, or nitrites
casey1999 is offline
The Following User Says Thank You to casey1999 For This Useful Post:
alctel (08-19-2014)
