How did you adjust the reversing gear? Did you tighten or loosen the retaining bolt?
The A4 does not have a reverse detente, so while the shaft may be spinning, it might not be spinning at high RPM's or it may be slipping. Even if the prop is very fouled, you should get something out of it.
