If your charger is plugged in and working you will get at LEAST 13+ volts as a reading at your battery terminals with the charger on. (14.4V or so would be normal bulk charging voltage and around 13.4V if the batteries are already pretty well charged. You should be able to get similar readings from your batteries when unplugged from shorepower with the motor running.
