Old 09-05-2007
sailingdog sailingdog is offline
sailingdog is a jewel in the roughsailingdog is a jewel in the roughsailingdog is a jewel in the roughsailingdog is a jewel in the rough
That is the proper way to cleat off a line. BTW, the angle formed by the standing part of the line and the cleat body should always be less than 90˚, since if it is larger than 90˚, you've lead the line to the wrong end of the cleat and there's a much greater chance that the line can jam under a load.
IMHO, there really aren't any benefits to additional wraps of the line around the cleat or extra figure eights. They just increase the chance that the line will jam and make it much more difficult to release the line.
If you're not cleating off the line, but using the cleat to provide leverage, then you should probably do what danjarch has mentioned above... the final turn with the bitter end tucked under would be a problem to release in a hurry.
If you're new to the Sailnet Forums... please read this POST.
Sponsored Ad
