Old 09-05-2007
danjarch's Avatar
danjarch danjarch is offline
Boat less in Texas
danjarch is on a distinguished road
There really aren't any benefits to additional wraps of the line around the cleat or extra figure eights. They just increase the chance that the line will jam and make it much more difficult to release the line.
You've probably got clam cleats on your boat, but if you don't, you never hitch the sheets or the halyards. After so long under a hard load, the hitch will lock up to the point where you can't get it off. Instead of a hitch you do multible figure eights around the cleat, usualy three complete wrap in total. This gives enough friction that you don't need a hitch. It also allows you to remove one wrap at a time, by compressing the underlying line while you remove the top line. You do this untill you have just enough friction left to control the release of say the main sheet.
By the way, if you use three strand, you need to make sure that your keeping the right hand lay when ever you cleat off.
!! WARNING !! The above information is to be used by intelligent people only. If you are Stupid, could be considered a moron, or otherwise. You are instructed to disregard this information and seek the help of a licensed and bonded professional.
