SailNet Community - View Single Post - Calling all crapper experts
post #3 of Old 06-03-2014
pdqaltair
pdqaltair's Avatar
Re: Calling all crapper experts
Trident 101 is considered the best value in a durable hose, but if you want something that will bend, you can't beat Raritan Saniflex (bend radius about 7"). It is also MUCH easier on and off the fittings, but will not leak. The permeation resistance is quite good, better than the white hose.
That said, any hose will kink if you force it. If it looks like it is starting to pin, insert a PVC fitting.
Writing full-time since 2014
"Keeping a Cruising Boat for Peanuts"
"Faster Cruising for the Coastal Sailor"
"Singlehanded Sailing for the Coastal Sailor"
pdqaltair is offline
The Following User Says Thank You to pdqaltair For This Useful Post:
Hush34 (06-04-2014)
