SailNet Community - View Single Post - Cored deck soft spot repair
post #75 of Old 06-04-2014
Quinn99
Re: Cored deck soft spot repair
Caleb - For your port side re-core where you re-glued the skin, do you think it would have been easier to bevel before you glued the skin down, or was it easy enough to do after?
I am still considering laminating the skin down as my port side is not even. I have leveled it as best I can, but think that a thickened epoxy with the skin would help smooth the bond and ensure it is flat and even surface. I am not confidant that I could laminate new glass and get the same result.
My starboard side is a different story as it is level and I would attempt attempt to glass it over. May try both???
Quinn99 is offline
