SD is correct that it is the amperage that kills you not voltage. A 12 volt battery, however, does not have enough voltage to push enough amperage to kill you. Ohm's law E=IR. The amperage usually quoted that will kill you is 10ma, that's why GFCIs are designed to trip at 5ma.
