SailNet Community - View Single Post - Forestay toggle(s)
post #6 of Old 06-06-2014
christian.hess
merit 25 solo "er"
christian.hess's Avatar
Re: Forestay toggle(s)
cool...yeah In general terms Im not a fan of roller furling but I understand its benefits but I also know there are many many many amateur and "pro" installations that are done badly inlcuding badly sized forestay or no toggles etc...
stays on furlers in general terms should be replaced twice as often as hank on stays...
so that translates to roughly every 5 years...
another issue I hate about most roller furlers is the inaccesability of the riggng under, most owner dont want to dissasemble the unit in order to check the condition of the swages or terminals etc...
Im also a fan of swaged stay up top and mechanical on bottom...a swaged up top wont suffer much crevice corrosion since water and stuff wont trickle into it, you save some money and you can get the exact forestay length for your boat with the use if any mechanical terminal you want
norseman, hayn, staylock etc...
anywhoo good luck
Islander 36 no longer for sale...its MINE!
Planning maiden cruise for November-December 2015 to Panama Canal! The planning begins!!!
christian.hess is offline
