Old 09-10-2007
JohnRPollard's Avatar
JohnRPollard JohnRPollard is offline
Sailor
JohnRPollard has a spectacular aura aboutJohnRPollard has a spectacular aura about
Are you referring to the 1977 model located in Ft. Lauderdale?
If so, that is a Crealock 37 yawl, as you point out. But it is not a Pacific Seacraft. It appears to be one of the original Crealock 37s that was built by Cruising Consultants (CC). When CC shut down (after building a couple dozen, I think), Pacific Seacraft acquired the moulds and built these boats for almost 30 years. Not many of the PSC boats were yawls (most were cutter or sloop rigged). The interior of this boat appears to have been built up entirely from wood, where as most of the PSC boats had a fibreglass pan (early on PSC sold some hulls/decks as kits, both with and without the pan). The portlights are different from those used by PSC too. And PSC did not use the saildrive engine arrangement (they put the prop in a skeg aperture and went with a conventional shaft).
The design has received many accolades and has a reputation for solid seaworthiness -- but I don't know much about the build quality of the CC boats.
