SailNet Community - View Single Post - Gel coat vs epoxy for hull
post #4 of Old 09-09-2002
JeffH
Guest
Posts: n/a
I am not sure what to tell you to do. If the marina was redoing your bottom because of blisters, chances are the new gelcoat will be even more pourous than the original gelcoat. If that is the case then I would think that the blisters would return in short order.
Probably if I were in your shoes I would apply something like Interlux''s barrier coat system.
Good luck,
