I don't know about how the SA/D is calculated for a Cutter-rigged boat, since I don't deal with them all that much. However, as I said, the numbers I gave you are probably a bit on the low side, since most mainsails are cut with some roach to them, especially if they have any battens in the sail.
The PSC 31, HR
Monsun and
Mistral, Westsail 32, are other boats you could look at. The HR Mistral will probably perform much better than the PSC31 and WS32, since they're fin keeled IIRC. The Monsun is a full-keel design.
To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts..
