SailNet Community - View Single Post - 9.8HP Tohatsu 2-stroke odd behaviour
post #11 of Old 06-14-2014
Minnewaska
Re: 9.8HP Tohatsu 2-stroke odd behaviour
I'm going to place a nickle bet on the mixture as well.
While it's admittedly a bit of witchcraft and not the same as pulling things apart, I do use this annually. I think it does a reasonably good job of keeping things clean, albeit cheating. You spray the entire can down the air intake, while running. It nearly chokes the motor to a stop, so you let up and then go at it again. Big smoke maker, makes you feel like you are doing something.
http://www.amazon.com/Marine-Motor-De-Carb-oz-aerosol/dp/B005IGNML0/ref=sr_1_1?ie=UTF8&qid=1402745512&sr=8-1&keywords=ValvTect+Marine+Motor+De-Carb
Jeanneau 54DS
Minnewaska is offline
