Thread: Shroud Tension
Old 09-15-2002
gnorbury gnorbury is offline
gnorbury is on a distinguished road
Shroud Tension
Generally the cap shrouds will be the tightest, followed by the forward lowers and finally the aft lowers. The objective with rig tuning is to pre-stretch the wire so you don''t have excessive flop when you load up the rig under sail. (i.e. leeward shrouds should remain under slight tension when you are close hauled in a good blow.)
Graham
